bad LPM or 80mm MAF?
Mr. Chad A.Meirose
Sioux falls SD
when I run the ted b LPM and 80mm MAF I get a surging iddle
pull out the maf for stock and unplug the lpm the problem dissapears
oh BTW the car seems to have more torque on the low end with the stock set up also faster response times.
any thoughts?
alum flywheel. tru-duals x2j computer :confused:
PROPHET
Well-Known Member
Tonytown, Texas.
Chad, do you reset the computer when you install the LPM and 80MAF?
You may also need cleaning on the 80 electronics and on the LPM.
twr
whoohoo
half-way there, I think.
Chad,
There has been a long standing issue with Ted's programming for an 80mm Lincoln MAF and the X2J PCM. If you have the X2J PCM, I would contact Ted and tell him what is going on. My 95' did this for almost a year. Come to find out, it was also running dead lean, which resulted in a warped intake valve. My last recollection is that Ted had figured out the problem and had programming to fix it. I finally had the ShoShop reprogram my before Ted had it figured out, trouble free for over 2 years now (but I wouldn't recommend sending anything to the ShoShop, as their future seems a little rocky and I suspect you want your LPM back before next year)
