alollich
Hey folks, I am going to replace the axles in the SHO and have determined that the center support bearing is bad. Does the center support bearing on the passenger side axle need to be pressed off or does it just slip off? If anyone has done this before any info would be appreciated. Also for those that have that annoying clunk in the front end and you have not been able to diagnose it try the center support bearing. Mine is bad enough that there is play in the bearing when you shake the axle. Thanks for any info you can provide!
