seraphiem
I installed an electrical 90° Sweep gauge. Yeah I know I should have went mechnical. Figured it would augment the idiot light as a rough indicator.
First off...how non-linear/linear is this thing? At hot idle its barely sitting above the 0 PSI mark.
And do they give precise results?
I've witnessed my gauge readings vary from dead center between say 37.5 for 3k rpms and then later 25 PSI for 3k rpms. Temps and conditions are almost always the same.
Note: Rod bearings were replaced about 1k miles ago as a preventative. I run 5W-30.
