ATF fluid change-how many quarts?
Joshw0000
North Carolina
The manual says 11.6 quarts for a full change. If you're just draining and refilling (not flushing) you'll only get about half of that in it.
My rule of thumb is to check the fluid level with the engine hot (to confirm its not high or low), drain it, measure what came out, add that much back, then check again while hot after running the P-N-D-R cycles.
Sent from my Pixel 8 Pro using Tapatalk
Joshw0000
North Carolina
Yea, I usually get just over 5 quarts. Like, opening the 6th and barely using any.
brackenbirch
