1982X11
Green Machine
1)My fuel pump makes a audible whine that is a bit louder than in the past.
2) Under moderate acceleration a couple quick hesitations, then back to normal. This has happened 3 times in the last week.
Check engine light has never lit up, and otherwise everything is normal. Thought I'd see if I was paranoid...
I have access to a shop, I assume this is a pretty easy job with a lift? And should I replace with a OEM pump or a 155 aftermarket?
Thanks to you veterans who have been down this road. I'd rather avoid finding out the hard way...
