Any good leads on a banjo bolt?
tasty danish
Missouri
i have a 92 sho with the 96 brake upgrade done and with stainless steel brake hoses.
i was installing new pads and my friend snapped a banjo bolt holding the hose to the caliper, i had to buy a normal hose for now but want to get the steel one back on.
problem is i went from part store to part store and no one had anyidea how to get the bolt. maybe they're just imcompetent?
anyhow, the current hose i'm using connects to the caliper with some sort of metal square that looks nothing like the original banjo bolt.
if anyone knows where to get one, please let me know.
and thanks in advance.
olympic
Saskatchewan, Canada
I used a standard 3/8x16 bolt to plug the banjo bolt holes when I painted mine.
NJSHO
Clean Your Shorts!
NJ
I’m guessing incompetent. I had the exact same thing happen to me, if you are talking about the stock banjo bolt. I just went to the no name parts store by me and they had a bunch of them in the red HELP boxes. I’m pretty sure every parts store in America has this section. I just went to Autozone.com and did a search for banjo bolt. After putting in the year and make of my car I got a return of them having a "Motormite" banjo bolt for a 91 Taurus for $1.99. Hope this helps.
EDIT: If you still cant find one paypal me some money and Ill pick one up and ship it to you.
tasty danish
Missouri
i appreciate all the help, but i just found out that my friend also cut the steel line for no apparent reason, so now i need a hose too. this kid is starting to tick me off.
anyone ever try to buy a single steel hose?
NJSHO
Clean Your Shorts!
NJ
Good Luck. You might want to contact the manufacturer directly if you know who that is. If it is Earl's and its a front line I might know someone who has one. Let me know.
