abs sensor plug location
Mike Kelly
Middleburg, Florida
I need to replace the left rear abs sensor on 90 gen 1. Can anyone tell me where the wire leads run to? It was late when I finished assembly and I did not have my manual with me. I wanted to learn the routing , so I don't have to go home to get the manual. Thanks Mike Kelly
Ishodu
Remove the lower portion of the rear seat you will find the 2 connections down there near the back almost under the vertical section.
Ishodu
The routing however is down the control arm through up over the gas tank and theres a plug there there then into the back seat.
