A few questions about o2 sensors, ATX vs MTX sensors,Denso vs ??
broke1
Alabama
Im needing to replace the o2 sensors and been searching......I've read about most sensors on the cars being Bosch and the o2 sensors on my 95 3.2 ATX car are a 4 wire setup vs 3 wire on the MTX cars.....
I'm leaning towards 2 of the Denso 234-4610. I've always had great luck with Denso (they are a main OEM supplier of o2 sensors) and I can pick up 2 for around $45 shipped.
Anyone used these and were satisfied?? If not,what o2 sensors did or have you used that you've been happy with ON THE 89-95 FORD TAURUS SHO??
Was the information I found stating that 93-95 ATX cars had 4 wire heated o2 sensor vs MTX cars having 3 wire o2 sensors correct or?? Im pretty sure it's correct because the sensors between MTX and ATX have different part #'s but u never know......
Thanks for any feedback!!!
Bosch alternator and O2 sensors worked fine as replacements on my ATX SHO. Original O2's were Ford-branded, NTK-mfr'd.
Yup, MTX = 3 wire, ATX = 4 wire
MTX: BOSCH 13942 OE Style Oxygen Sensor; Heated; Wires: 3; Length (in): 10.8 Heart
Fits Upstream; For Part number E7TF9F472AA; For Part number E77F9F472AA; For Part number E77F9F472BA; For Part number E93F9F472AA; OE manufactured part
Or Upstream; For Part number E9SF9F472AA; For Part number E97F9F472AA
NTK 22013 NTK OE Type
ATX: BOSCH 15716 {#13127, 15718} OE Style Oxygen Sensor; Heated; Wires: 4; Length (in): 10.6
Fits Upstream; For Part number F4AF9F472AA; OE manufactured part
Or Upstream; For Part number F0SF9F472AA; For Part number F4DF9F472AA; OE manufactured part
NTK 22500 {#22109} NTK OE Type
the Denso oxy sensors have worked fine for me on the SHO.
itwonder
VA
I am using Denso O2 sensors on my MTX , and they have been fine for several years. Like you, I have had good luck with the Denso brand
sperold
Last to Know
Denso is a trouble free O2 sensor and the original Motorcrafts are fine as well.
I did not have great luck with Bosch, but that was back in the time that I had other people installing them.
I think if they get mishandled or dropped, it has a big effect on how they work or how long they last.
