A/C off, code 528?
JoesSHO
Reality
I ran my codes today, and got the following:
114
116
528
565
I know the CANP is bad, I have to bypass or replace that.
The ECT I was unaware of, would that cause bad mileage? Like 15-19 MPG? Becasue of improperly reading the temp, and dumping timing like a bad O2?
The IAT I think is showing bad becasue it is about 35 deg here...
The 528? shrug
The A/C was not on at all- in fact the whole CC unit was off. ???
Thanx!
projectSHO89
SHOless In St L
Clutch switch, not the A/C.
There is a two-part clutch switch. One serves as the starter interlock, the other signals the PCM than the clutch has been pressed to a) be able to control RPMs and b) dump the cruise control, if engaged.
Steve
JoesSHO
Reality
Could the code pop becasue of the alarm locking into the clutch switch, and me turning the key without pushing in the silver alarm button, then doing it the right way?
The clutch switch works fine... ?
Thanx!
JoesSHO
Reality
Hmmm, I'll try that tonight.
I think it had something to do with the alarm.
Thanx again
