what is the best set up to use?? stock type or aftermarket??? i am a big fan of kyb what works best, all around use? thank you.
97 sho rebuilt engine, welded cams, rebuilt trans, cobra front brakes (rotor & calipers), cold air intake custom 76mm MAF, GP adjustable rear arms, getting ready to install 3" flex with cat deleat, 3" dynomax bullet muffler in the mid pipe branch off to 2.5" with two 2.5 bullet mufflers with tips.
thank you for your help if you can.
