95 SHO door codes
The_Vigilante
Texas
Just bought a 95 SHO ATX. Is there anyway to determine the door codes to open/close the door?
nickdodd25
Oshkosh, Wisconsin
For the unlock code, look in your trunk on the left side on the back of the back seat behing the cover that covers the factory ford amp, there should be a little black box that has your numbers on it. Type it in your key pad on the door and it should work. Then press buttons 7/8 and 9/0 to lock the car. Also there is other nice things u can do to...Press 1 after your code to add another code to your car.
Press 3 after your code to open all the doors.
Press 5 after your code to open your trunk.
Hope that works for you! Good luck on the new SHO!:wave:
