94 ATX Pulling motor/tranny
SHOTIME
Giver of life
Boston Ma.
Ok, Im getting ready to pull the engine in my 94 ATX. Anyone know if I can do it without breaking the two apart?
Ive heard the out the top and out the bottom stories, Which will work best for me.
And how much do I need to pull off the motor to get it out? Front of the engine wise.
Can I leave the alt/Waterpump/pulleys on? or should they all come off?
Thank you all
BTW perhaps Ill just take a sawzall to the frame...
Eric
mailto:[email protected][email protected]</A>
My Web Space
New England SHO Specialists
Rob94
Northbridge MA
Eric, are you doing this today?? I have the day off, just have to go to work for a 2 pm meeting, which should be over within an hour.
Rob
White 94MTX
K&N Filter otherwise stock
P
Prophet78
Guest
I have seen it done with Engine hangers. When Chuck pulled my tranny he lifted the Engine, put a tranny support under (Yep you guess it )the tranny and pulled the subframe out and wheeled the tranny out from under the car. This was all done on a lift of course. I am sure from there you can hook up the the engine to a pulley and lift it out.
-Jeremy-
'93 Red ATX "Red Phoenix"
E-Mail Address: mailto:p[email protected][email protected]</A>
Webpage: http://prophet780.tripod.com
Some Mods
speedy91
West Des Moines, IA
You can pull both the ATX and the engine together if you drop the subframe out the bottom. We did this a few weekends ago. I will e-mail you some pics. Let me know if you have any questions. Just look out for those subframe bolts if they have not be recalled. They are a (*#^$()#
Eric
1991 Ford Taurus SHO Plus: High-revs clutch, lightweight flywheel, K&N air filter on cold-air induction, 73mm MAS, custom programmed chip, under drive pulleys, high flow y-pipe, Walker/Dynomax exhaust system, 96 brake upgrade, Eibach springs, Koni struts, sub frame connectors, front and rear strut-tower braces, polyurethane bushings, aluminum front sub frame bushings, white gauges, matching aluminum/carbon fiber pedals and shift ****.
Coming this spring: SHOShop MTX with Quaife. 3.2 with 3.0 heads. Borla cat-back. Baer brakes. 17x8 Momo Arrows with 235/45R17 tires. Custom black interior.
Shoman94
Maine
Originally posted by SHOTIME:
My hero.
Nice so you just lift the car off the subframe?
Yup, out the bottom. steering and drive shafts have to be removed.
'94 MTX Silver
Tokico Struts, Eibach Springs, Spmotorsports SubFrame Conn. 29mm ShoShop Rear sway bar, Shohop Cat back, Gutted box with K&N, '96 Brake Upgrade, White Face Guages.
Shoman94
Maine
Do you have AIM?
Mine is Billebobob
yep....
shoman1994
'94 MTX Silver
fordfanatic4ever
middletown, ri
I have a 30mm socket, i live in Newpot RI, used to live in north attleboro, and that is where my garage is, but the socket is in RI because i thought i would need it when i upgraded to 96 brakes.
Terry
Nope, weekend.
car is 90% prepped though.
Its pretty sad to see so little of the car left.
Anyone in NE have the 30mm Socket to remove the front axles?
