91' sway bars: Good for a 95'?
Paulm
Wenham, MA
Just wanted to know if 91' front and rear sway bars are right for my 95'. I'm looking to upgrade bar size. Thanks.
They are good if you are looking for the increased roll stiffness of the Gen Is. Be aware that you will need new bushings to install the bars to the body since the bar diameters are a bit larger. This would be a good opportunity to upgrade to polyurethane bushings to increase the roll rates that much more. The rear bar is not too difficult to thread through, but the front bar will require that you drop the rear of the subframe.
Paulm
Wenham, MA
If I drop the sub frame for the front swaybar, is this a good time to replace the subframe bushings.
Also what is best to replace them with, aluminum, Poly, or rubber? Is TPR available?
