91 sho throwing codes
phreaksho
Honda Slayer
Waukeshaish, Wisconsin
is throwing code 91 (R, M) System running lean - Fuel controlll
Transmission SS 1 circuit/solenoid problem - Transmissions
just put the tranny back in and got it running took it on a test drive and it threw this code have no clue where to start on this one any advice is appreciated
bubba
ATX Connoisseur
Fort Wayne, Indiana
the first one is a o2's are bad! the second on I'm not for sure right off hand! can you put up the code numbers?
Storm-Chaser
Shit Louis
How's engine temp - has the TEMP gauge running slightly higher than usual?
On an ATX car I had - I began getting oxygen sensor lean codes, and then transmission codes about the time I began to notice slightly elevated water temp. It ended-up being the first noticeable signs of clogged catalytic converters.
phreaksho
Honda Slayer
Like he said car hasnt run i. 3 years and has a sho shop catless ypipe and that is one code code 91 but the whole definition says lean and a tranny solenoid problem doesnt make any sense to me maybe the o2 is bad but what does that have to do with the tranny solenoid? :(
