80MM Maf questions/Problems
SHO Off
Winnipeg, Manitoba, Canada
Ive had a rough/surging idle and surging when driving at higher rpms, feels like engine cuts in and out since Stage 2 kit when on. Tried reprogramming LPM, didnt help.
Today I disconnect MAF, and surging didnt exist and it idled smooth. Ran around town for 30 mins with unplugged and had no problems, even felt like power was smoother... Any ideas about this?
Maf bad? LPM needs reprogram??
http://come.to/shocw
14.9 @ 94 mph
91 SHO plus Black
Police Grill, Rod shifter, Strut tower braces. 80mm MAF, SHOshop CAI, UDPs, SHOshop LPM, Big Bore Butterflies, Ported Intake Runners, Port match enite Intake Manifold and Intake ports on Heads,Dynomax cat-back w/2.5 inch tips exiting through bumper. Painted SHO lettering Yellow. Homemade Shorty SFCs, Alum SFBs.
Ypipe on Order!
"SHO OFF" Plates
80 Camaro
325 hp 350 ci. Custom Paint, wheels. Shift kit and all those goodies.
fredhurderjr
www.neshospecialists.com
I had to replace my IAC once the blower went on. Could be a bad MAF, but check the harness too - my "bad MAF" cost me $300 for a replacement (which it wasn't), plus fixing the harness (which it was). Luckily, someone bought the new MAF from me for my cost.
SHO Off
Is the harness the actual MAF plug... Cuz that was changed along with the speed sensor about 1 month ago...
14.9 @ 94 mph
91 SHO plus Black
Ypipe on Order!
"SHO OFF" Plates
80 Camaro
M
Mikeys_Taurus
Guest
When you disconnect the MAF and your check engine light comes on, the car is running in "limp" mode. If you have a problem, such as I did, then the car will feel much improved when in that mode. Have you run your codes?
SHO Off
I do get my check engine light on when the MAF is disconnected... and it does seem to run better... Although Im guessing pulling codes at this time wouldnt really do any good, cuz it gonna say something due to the fact my MAF is not connected... Im just wondering if my MAF is the problem, or the LPM controlling the MAF??
14.9 @ 94 mph
91 SHO plus Black
Ypipe on Order!
"SHO OFF" Plates
80 Camaro
M
Mikeys_Taurus
Guest
Why don't you plug it back in, clear your codes, drive it for 50 miles?, and then run your codes. Then you can get an idea of what it is. I think.?
SHO Off
Well I never threw any codes when it was plugged in, thats what baffled me... although I plugged it back in tonite, and seemed to have no problems yet... We will see what happens tommorow once again after it sits outside, and gets all cold all nite...
14.9 @ 94 mph
91 SHO plus Black
Ypipe on Order!
"SHO OFF" Plates
80 Camaro
