Bluto,
It has been my experience that a sensor that is expected, by the computer, to draw UP TO 5 volts, will not "code" as long as the sensor is drawing 5 volts, or less.
However, a sensor that is drawing close to 5 volts is very likely to be on its way to failing, and may be causing intermitent problems.
Many of the sensors can be tested for the amount of ohms, (resistance) and determined to be good or bad, depending on the test results.
Would someone please post the resistance peramiters, and other test proceedures, for the various sensors?
I have also found that very frequently the problem is a poor electrical connection, often due to corrosion. I recently spent about 20 hours cleaning connections and coating the connectors with Kopr-shield.
Kopr-shield is like anti-sieze compound, but is copper in color. It is available from Eastwoods, and may be available from a local auto parts stores. It is specifically made for electrical connections. A small bottle is about $8 plus shipping.
There are also some greases made to keep electrical connections clean and promote conductivity. Would someone please post the brand names of these, and where to get them.
Lastly, check ALL of your GROUND connections. Make sure they are clean and making good contact. Hope this helps, rangerj
