556 - Fuel Pump Relay Primary Circuit Fault?
mrgrim333
Colorado - Northern
So my check engine light keeps kicking on every once in a while, and I just so happen to have a eec tester. Pulled the code and got a 556 - Fuel Pump Relay Primary Circuit Fault.
How do I go about fixing this? I want to get my emmissions done but won't they fail you for a check engine?
91PDXmocha
Portland , Oregon
Probably going to need a new fuel pump . The fuel pump has it's relay inside the corm which is the black box on drivers side above of the radiator.
crystizel
