2nd SHO owner
SCSHO13
Central Fl
Hey guys, I previously owned a 2011 Sho. Now I have a 13 Sho. A couple things if anyone can point me in the right direction. I am not sure if I have the performance package or not. Someone I met in person believes I do but I want further verification. Also I want to an air intake and cat back swap. Maybe a tune but I just to keep it simple. If anyone can send a couple links that'd be great.
Happy Thanksgiving!
76FoMoCo
Nampa, ID
Look in the trunk if you do not have a spare tire and only an air pump you will have a PP Looking at your avt i bet yours is a PP car.
Your best bang for the buck on the cia is just a drop in K and N and keep stock exhaust until you put a tune on it. both intake and exhaust from the factory work well.
https://www.livernoismotorsports.com/product/LPP350102 there are other tunners out there but this one is easy and a solid product.
You can also get it without the cia and add the 3 bar map.
SCSHO13
Central Fl
I do not have a spare. I figured this baby was more juiced up. When I test drove it, I immediately felt a difference.
I was considering k n CIA, but also putting the borla cat back. Inbox me
76FoMoCo
Nampa, ID
I wouldn't do the full cia I would just do the replacement filter. did you look through the car for a tuner? you can also youtube the 3 bar map change and look to see if your part number is a 2 bar or the 3 bar this will let you know if it has a tune on it.
as for the borla you will have to do some digging in the 4ms. I would much rather spend the money on other stuff as I like mine quite.
SCSHO13
Central Fl
Im just doing research at this point. I appreciate the insight. I'll look it up
SCSHO13
Central Fl
So if it in as the 3 bar, that means its tuned?
SCSHO13
Central Fl
Word thanks for the info I'll pop the hood tomorrow. Happy Thanksgiving bro
