EBOLA6
Just wanted to say that I did my first vcg job and it went more than well! I was able to complete the whole job in about 6 1/2 hours. There are no oil leaks, engine has its power back, no smoke ever came out of exhaust, yahoo!
I want to thank Scott for the OUTSTANDING instructions he sent me on how to do this.
For those of you who are considering doing this but may be a bit hesitant...make like a shoe and just do it! Here are some tips I want to include that should help the lay person out...
-use tape and sharpie to label each hose/wire you disconnected and the part it came from
-radiator petcock valve (white in color) "almost" comes completely off before the fluid starts to flow
-use "a little bit" of gasket adhesion to hold gasket onto valve cover(especially for rear cover)
-after completing job, run car for a few minutes, then be sure to check for hose leaks. I forgot to tighten one radiator hose clamp and she leaked, but i was able to catch it!
Otherwise, Scott pretty much covered the everything you need to know! Good luck!
