GT94SHO
Price reduced to $3,499
Originally a CA car brough to AL. No rust anywhere...
Upper 60k done
New timing belt
Replaced timing belt tesioner
New crank position sensor
New cam position sensor
3 new camshaft oil seals
New crankshaft oil seal
New front motor mount
New water pump
New thermostat
New radiator
New hoses
New starter
New cats
4 new struts & springs
New EATC
Good Toyo radials
Trans fliud change
Reman. pass. side axle
New rod bearings
New main bearings
Fresh plugs & wires
2 new 02 sensors
All new idlers
Very reliable
Hoover, AL near Birmingham
Upper 60k done
New timing belt
New water pump
New thermostat
New radiator
New hoses
New starter
New cats
New EATC
Good Toyo radials
Trans fliud change
New rod bearings
New main bearings
Fresh plugs & wires
2 new 02 sensors
All new idlers
Very reliable
