shoshirtsandhat
Hello all, I have had this issue for 6 months now and I want to fix it asap,slow leak (motor oil), there is smoke coming from under my hood pass side after the 94 ATX is warmed up. Expecially after the oil is changed and FULL, I dont believe it is a oil sending unit because I read that it is located near the master cylinder side of the engine and it really wont drip on the cats ,exhaust etc. When I look with my flash lite there is oil saruration on the top of the power steering pump behind the belt! It is not steering fluid because it is all ways full. Could the leak be valve seals ..the valve covers were replaced 2 yrs ago by my mechanic. is there any pictures of the valve seals fix? Not sure but what do you suggest.
