Sunroof tilts but wont slide back
boat
Likes blue ones
Tallahassee, FL
Sounds like you might have a bad switch. Shorted pins 1-4 of the switch harness that plugs into the motor/related wiring. As soon as we plugged it in, the roof tilted up (or vented) but wouldn't come back closed.
Could be the switch... Start there first, cheapest part to replace... I will PM you a test to check your switch, gimme a little bit though.
medgraphsho
Bill T.
Bridgeport, CT
maybe your confused. It does tilt open and vents, and it does go back down to fully close. Thats all it does, it will not slide open at all
boat
Likes blue ones
Tallahassee, FL
My sunroof tilts up and back, but dosent slide open?? Is it off track? Where do start?
In your first post you never said that it closed. You were not clear as to if it closed or not, and no I am not confused. Had you stated to begin with what you did just on your last post, that it does close, I would not have suggested the switch. I threw my .02 in b/c mine opened to vent but never closed, your problem sounded like a switch from the start, apparently it is not...
shobroooo
