My SHO is s-s-s-STUTTERING!
GM Reszel
NE IN
Hello everyone thank you for this forum! I have a 93 SHO. As I'm driving, whether I'm accelerating or decelerating as I get near about 2k rpm the car jumps and stutters in power, sometime rather violently. The engine light comes on every so often but never in correspondance with the stutter problem. The problem doesn't always happen in this area of the power band but does happen quite frequently. I have just recently replaced fuel filter, plugs, wires; I almost always run premium.
Any expertise would be most appreciated, email me or call,
Best regards,
Greg Reszel, 260-760-5499
itwonder
VA
Did you try cleaning the MAF sensor? TRy running with the MAF disconnected and see if it's any better or worse.
baySHO_510
**** It broke!!
Manteca & Oakland Ca.
Make sure that you dont have any vacuum leak in the canister behind the intake manifold. A little hose coming from it to the manifold was making my car stutter pretty bad in the past.
CARLISLESHO
i luv my SHO
pa
i had that problem check your o2 sensors and make sure they are pluged in if they are take them out and replace them that should fix the problem
CARLISLESHO
i luv my SHO
pa
been there
i had the same issue try to *** by cheacking ur o2 sensors that they are pluged in and workin if they are pluged in replace them they are not very expensive
GM Reszel
NE IN
Thanks so much for your response kids, I'll check these things,
Best regards,
GM Reszel
dan.delargy
