Storm-Chaser
I order fuel injector o'rings yesterday morning, and the AutoZone Hub store sent the wrong ones - imagine that ! :laugh_ti:
The o'rings I ordered were Fel-Pro part number 92326, which come boxed in a pack of four (4 ?) under Fel-Pro o'ring gasket set ES70600. Here's AutoZone's webspage for reference:
Here's what I ordered: Fel-Pro ES70600
Here's what they sent: Rol CM55405 (note how they're packed in a quantity of four as well)
Many 'smaller' companies will often make their part numbers the same as a major supplier, such as Fel-Pro, Raybestos, TRW, etc.
nono
In this case however, AutoZone sent gaskets that clearly were *NOT* Fel-Pro, and that were prominently marked "ROL Gaskets" (product packaging clearly states "ROL" in promient RED lettering against a blue background, with "www.rolmfg.com" on the damn package
), the ROL packaging prominently lists three part numbers vertically:
So why the post? Here's the dilemma. The Fel-Pro o'rings are made in Taiwan (not Japan), and the ROL's are made in Italy. Of course, the AutoDrone idiots (including two store managers) tried to convince me first that they were Fel-Pro, then that ROL is owned by Fel-Pro and thus they "routinely" will substitute these in place of Fel-Pro. Well, I don't think so.
Here's the dilemma. Neither are OE-source (ie. from Japan) and I've generally found Italian-made parts are of pretty good quality. So, has anyone used the ROL gaskets - which AutoZone has been shifting to - and if so, are they of the quality of Fel-Pro brand gaskets? Does anyone recall if the SHO injectors were OE-sourced from Denso?
), the ROL packaging prominently lists three part numbers vertically:CM55405 (ROL's part number)
FP- ES70600 (Fel-Pro's part number in reverse bold print - ie. bold white letters against a large black box)
VIC (GS33277) (Victor Gaskets)
errrrrrrrrrrrrrrrrrrr...
