rear control bushing replacement?
quikSHOilver
Yamahaized
Indy
I have been looking around for rear control arm bushing replacement because I don't see need to replace the whole 4 arms, I dont plan to track the sho. If there is no replacement then last resort will I purchase such arm from shobros.
hawkeye18
Sorta cares
Norfolk, VA
so... was that a question, or a statement? I'm confuzzled. Anyway, if you were trying to ask where to get the bushings, I'm sure Moog sells them. look at rockauto, I think they have them.
n8rsk8r
Hey Where's my post?
Olathe, Kansas
I bought a set from Vadem before he closed the shoshop, took me like three months to get them but I have them, still haven't put them in. I was in the process when one of the rear bolts broke off on me, I have to tap it and back it out before I can go on. The bushings I have a red urethane. Don't know if there are any more out there or not, but there was options at one point in time.... I hope that helps :shrug: good luck :)
LOUDSHO92
Rancho Cucamonga, CA
We have the eccentric bushings for the rear so you can get some adjustment out of the rear.
quikSHOilver
Yamahaized
Indy
Which in the rear does it replace: outer one connecting the knuckles or at the center? IIRC there is already factory set up eccentric in the center?
