'91 SHO for sale
sportfan
Ponca City, Ok.
I have too many cars and need to sell my '91 SHO. It is in VGC. The body is straight, and it looks to have been repainted at some time. White with black interior and the white sawblades. It is showing 59,800 miles and runs fine. To me the clutch is stiff, and the shifter is also but, I used to a Fiat 500 with a quick shifter and hydraulic clutch. The front seat show some wear and the back seat has some splits. It has an aftermarket stereo and I don't have the OEM one. As far as I can tell everything else is original. I did change out the ignition lock on the steering column. I kept the old one not knowing if it can be repaired. I haven't figured out the door locks yet, it has the number pad on the doors. I'm asking $5500 obo. I'm in north central Oklahoma and don't mind driving it a reasonable distance for a sale. I put two new tire on it today.SHO 1SHO 3SHO 12SHO 21
ScotSHO
Lewiston, NY
Hi there. I have a couple of questions:
- So do you suspect the car actually has that low of mileage, or do you think it has turned over once (159k miles)?
- How long have you owned it?
- Any modifications that you are aware of?
- How is the A/C?
- Is the shifter boot/plastic cover missing (I can sort of see it in the photos)?
Thanks!
sportfan
Ponca City, Ok.
- How is the A/C?
Thanks!
I don't think it has rolled over on mileage. The pedals or driver's seat doesn't look that worn. I've had it about 3 months. The only modification that I'm sure of is the stereo has been replaced. The ac works fine. I have the shift boot off to see if it was cables or rods going to the shifter. It was cables. Someone had asked me if it had been converted from cables to rods.
sportfan
Ponca City, Ok.
It's not overspray, must be the lighting. The headlights are starting to get cloudy. When I get around better, I'll get a 3M polishing kit to fix that.
