Hey guys, I’m absolutely at my wits end chasing this so I think it’s time to reach out. Car is a 2015 non PP. Has 160 t-stat, 542 plugs, 3 bar map, EPP dual intake and hot pipes, LMS catted downpipes, corsa cat back, LMS HPFP, GH Intercooler, AD trans mounts, and running a GH tune.
I’m having trouble chasing down my high fuel trims. At idle, long term fuel trims sit at around +20. Under load, they drop to around 8. If I run E30 or it gets cold outside, the fuel trim goes high enough to finally pop a P0171 or P0174, but even when the codes aren’t present the fuel trims remain very high. If I reset my KAM, as soon as the car goes in closed loop, the short term trims jump up until the long term starts to take over.
I have swapped between GH, my LMS, and my stock tunes with no changes so I know the issue is not tune related. That also eliminates my MAP sensor and my HPFP since both of those have been swapped to stock to flash the stock tune.
I have inspected and cleaned my MAF, no changes. I’ve replaced the rear bypass valve due to a torn diaphragm, no change. I’ve replaced both upstream AF sensors, no change. I’ve disconnected the catch can and returned the PCV system to stock, no change. I’ve smoke tested the exhaust system and confirmed no leaks are present.
I’ve spoke with Matt about it and he suggested trying a fuel rail pressure sensor which I have not yet had the opportunity to try. My local ford dealer basically told me to kick rocks.
Any Ideas?
Any Ideas?
