Alll aluminum radiator
gamefanatic
Barstow, CA
Gen 1&2 are setup a little different than Gen3's with the filler cap. Pretty sure the mounts are similar, but not sure about the accumulator setup.
MarcusKars22
Back in the Game
American Fork, UT
Thanks for the info guys. I found a radiator, but the factory cap doesn't seem to fit it correctly. What are people using as replacement caps?
gamefanatic
Barstow, CA
Are you talking Gen2 caps or Gen3 caps?
Gen3, I just use a standard one for the reservoir. Mine came with it.
Gen2 I have no experience with the SHO's, but used standard off the shelf versions in my older Tauri.
The openings are usually standard size so get the correct pressure rating 16lbs. I would get a motorcraft but the prices are usually very cheap for any brand.
