Door Actuator?
jazzplr
Lafayette, IN
My driver's door won't lock or unlock via the fob or buttons but the rest of the doors work fine. It will unlock if opening the door from the inside though. Does anyone have any experience troubleshooting this or have a procedure for replacing the actuator, if that's the problem?
ridered74
I think there are two main causes that people have seen. Replace battery in key fob, if that does not fix, replace vehicle battery. Sounds crazy, but borderline bad batteries cause lots of weird issues in these cars. I've never heard of anyone having an actual part inside the door go bad.
Johnbigdog
michigain
I disagree with either battery going bad.
I think the door latch in the door is either bad, or there is a damaged/broken wire somewhere.
The key fob sends a radio message to the Radio Transciver Module/Tire Pressure Module which will then relay the message to the Remote Function Actuator module or the Body Control Module . The RFA/BCM then locks and unlocks the door. The three passenger doors are controlled together. The driver door is usually controlled by a separate relay. This is for the stepped unlock if you so choose to use. (Driver door unlocks, then all doors unlock)
If the key fob was bad, all doors would be afected. If the 12v battery was bad all doors should be afected. Although I dont disagree with testing the 12v battery, its lower on the list.
The door latch itself will have two circuits that reverse polarity to lock and unlock the door.
If there is some movement from the lock rod when locking and unlocking the door, there could be high resistance on a circuit or a door latch that is bad.
If it doesnt moves then there could be an open on the circuit or a bad door latch. That flex joint between the door and the body is a common area with Ford for wires to break.
One will have to get the multimeter out and figure what's going on.
Since I'm on the mobile I dont see signatures so I'm not sure of your cars modle head to give you wire colors to look at.
Majestic
My car periodically does that, too. I just squirt a couple of drops of WD40 down the hole in the door panel and that fixes it for a couple of months.
jazzplr
Lafayette, IN
Well, balls! Wish I had thought of that before dropping the $$!
SHO307
CO
I've had this myself. First time was the DS front door. Got that fixed under the CPO warranty. Now "Ragin' Bull" has run out of the extended warranty, and this last week the PS front door stopped working.
This new occurrence has a twist though: the door lock plunger can be down in the locked position, but the door will still open. I'll try to push the plunger down---it'll bind as it's going down. Once in a while, it'll work like it's supposed to.
