Kevlar07
- Joined
- Feb 8, 2017
- Messages
- 18
- Reaction score
- 23
I was curious if anyone with a non PP sho had added on the traction control switch to disable the advanceTrac? I found a link on another forum that says it can be done with the switch adding a wire between the switch and Interment panel and changing the as build data to recognize the switch input. I'm looking for confirmation that it can be done or not. Tried to use Fords software to check on the as build/programable parameters with no luck so if it can be done it will be a Forscan affair. Link to the post
https://www.ecoboostperformanceforu...1788.15.html?PHPSESSID=6J6MK45jslzzQc5oOzAM53
