Crizcocane
I'm new to the SHO and became a huge fan of them at the races last year, when a turbo show ran the races all nite long. It was bad a$$ seeing the front tires go up in smoke and it left Mustangs Camaros and whatever else lined up next to it in the dust. I was looking for one for over a year!
I finally found and purchased a 91 SHO three days ago. She is in need of lots of love! I could use some advice in finding some answers to problems it's having. 200K
1. Battery light is on. Alt and battery checked out good at orileys and I dont notice dim lights or anything out of the ordinary. I checked many grounds to make sure they were tight. Also cleaned terminals and battery post. Any advice?
2. Oil in plug wells. I did a tune up on it plugs, wires, and coil pack. I believe 3 plugs had oil on them. One had alot of oil... What would be an estimated cost of having the valve covers and spark plug o rings replaced?
3. Shift linkage bushing are terrible, it does stay in gear but has wayyy to much play. Can anybody show me wear these can be purchased? I bought a excedy clutch kit and when I get the linkage I'm gonna have it all done together. What should I expect to come out of pocket for that?
4. The motor seems to run great previous owner said he did timing belt and water pump. I do believe him as the belt is not cracked and it is now a gates belt. I have read on here that rod bearing tend to go out...... I don't wanna **** my car. Is there any way to check that the rod bearings are in good condition?
5. Where is the camshaft sensor located? My SHO randomly started jerking and acting awful after I topped the oil off yesterday. Ive read that this can happen when oil hits the camshaft sensor. I want to replace the sensor and gasket. After the tune up today it had no jerks of any sort. Could oil coverd spark plugs been to blame? Still want to do the sensor either way.
Lastly, anybody have advice or suggestions of things to replace on a show with 200k+?? She needs lots of suspension and steering work done I'm gonna get on that asap.
Thanks in advance everyone!!
