Any lanching tip & tricks?? Advactrac or not?
Lorenzo Dimas
El_SHO
Hello to everyone, im am a new to the forum, ive been a proud owner of a 13 sho with pp having fun taking out all kinds car so i ordered an unleashed tune to get more out of it and it just came in last night,i got torries 93 octane tune paired wit a drop in K&N filter boy did it make a difference now have some spin at the wheeles(brand new falken ziex ze950 255 45 20) i was wounder how everyone gets off the line. Really didnt get to play around to much in it but i know spinning anit winning lol any tips guys?!?!20170225 133325
bpd1151
Lurking Around
SHOcago 'Burbs
On the street...tires at 27-28 psi and launch around 16-1800 rpms
Dragway...tires at 22 psi, around 2200 rpms, shallow stage, miss water box, do a mini burnout to clean tires
Nice to see you still coming out of the lurking wood work every now and then Rich.
Boosted Sho
You got trac off worthless imo sport mode everything still active less intrusive and advanced track off disables all nannies .
Boosted Sho
To much spin on front car won't like it. I'm learning a launch now on meth. Finesse the pedal vs to the floor I get a slight lag.. still whoop ass on what has wanted a dig so far
StealBlueSho
NA
Fronts I am assuming?
StealBlueSho
NA
I go all 4 to keep from throwing off the advance trak
Curious... depending on which tune I am running, the advance trak kicks off on launch because i believe the front end comes up too much.. front wheel spin doesn't seem to be a factor because TCS is off...
Have you played with just the fronts lowered to help reduce the amount of front end lift?
SHOnUup4
SE MI
The most I've had for a difference from front to rear was...22 front, 26 rear...no real difference that I could pick up on.
With coilovers, and the car slammed to the ground...I get very little upward movement on launch.
shaneirish
NY
I've tried launching at 2200 and at idle, lower tire psi vs recommended pressure, combinations of each and have found very little difference in my 1/8th mile times that average 8.4 seconds. I avoid the water. Traction control on did increase my 1/8th time by about .2, and every 100 pounds of weight adds .1 seconds.
crystizel
