GEN I Cable Shifter Clip
Bill Strobel
theamcguy
Fayetteville NC USA
There is a clip that holds the cable onto the shifter on the early GEN I SHOs. Now this link here gives the Mopar Part # for a substitute part http://www.shoclub.com/SHO History/shifterrepair.html What I want to know is what is the original Ford Part # for this part? I have looked through the parts books and the illustrations and cannot find this part, unless I am missing something. Was it supplied only with the cable? Does anyone have a photo showing the part on the car or what the part looks like? Does anyone have a good used one? Thank you
SHOspazz92
Banned
Triad Area, North Carolina.
Unfortunately that bushing was an integral part of the shifter cable. So I don't believe it was ever sold separately. The reason I say this is because when I had to install my SHOsource replacement bushing, you literally cut the old bushing off to get the new one on, as illustrated here....
http://www.shosource.com/catalog/article_info.php?articles_id=6
FWIW, I used the Mopar clip first and it wasn't exactly a perfect fit, it also left a lot to be desired on the feel of the shifter. Once the SHOsource unit was available I immediately got it to replace the Mopar Clip. The SHOsource replacement is not only much more stout then the original, but certainly improved the shifter feel as well.
http://www.shosource.com/catalog/product_info.php?cPath=61_5_29&products_id=340
-Sam
Bill Strobel
theamcguy
Fayetteville NC USA
That makes sense. I figured it had to be part of the cable as the parts book does not show it as a separate piece. Will get the bushing to tighten up the shifter then.
MR-R1CHTER
Sellersville, PA
My 95' SHO Mtx is in the shop now, i was waiting to hear back from the local performance shop after taking it in with gear change problems, turns out it was just that bushing. I left a trans in the back seat in case it was severe lol. The guy fabricated his own to fix my problem. They break after a while, my car has 112k on it.
SHOspazz92
Banned
Could not have been that clip, unless you converted your 95 SHO to a cable shifter. The 89-91 SHO had a Cable shifter. 92-95 was rod shifters.
-Sam
