Tire Size
shojoe1997
new york
I need new tires on my 98 soon, i know ford reccomends 225/55r16 size for this car. But i dont really like how "beefy" the sidewall looks. Has anyone tried 225/50 or 225/45, or any other tire size on the stock wheels? If so please post pic or pm pics.
Thank You
Joe
98SF19
AlphaKennyBuddy
Florida
non oem
I don't know about the sidewalls, but just changing the tire size away from OEM on Tire Rack dropped the price significantly, some more than others. I think I actually went with a beefier sidewall to try to avoid scraping my splash guard on the curbing at work as I pulled out. It didn't help, but I got each tire for about $15 less than the OEM from the same manufacturer. This was about 2 years ago. It seems that the franchises (General Tire, Tire Kingdom, etc.) have dropped their prices to compete with on-line sales. I'm waiting for a Korean-owned chain to come along and put all these other shops' lights out. Not that I'd be happy to see that happen. But I digress.
stephen newberg
Ladysmith, BC, Canada
In general, if you are keeping the 16 inch stock wheel size, as you decrease the sidewall by 5 you want to increase the width by 10 to keep about the same circumference so the speedometer works correctly. So 235/50 or 245/45, for example. What you then have to watch out for are two things. First, you do not want to get too wide for the wheel, that is getting the sidewalls at an angle instead of more of less straight up and down. The tire manufacturer will indicate a range of wheel widths that the tire is designed to work with, and you should not go past that range. Second, you need to make sure that the tire does not start to contact the strut. As you get wider, your margin there decreases. From my past experience with this, the 245/45 is as low and as wide as it is possible to get with the stock wheels, and only one tire was made at that time (a long while ago) that was in that size and still in width range for the OEM wheels. It was a Bridgestone, but I do not remember the model number.
Anyway, those are the things to look out for. Depending on what is made these days, you might find it simpler to go to 17 inch wheels to find a selection of possible tires, though you will still need to keep both of the above limitations in mind.
pax, smn
Ian Macoomb
Ottawa, Ontario, Canada
I ran 225/50's on my car. I also had some 225/60's on it at one point and 215/60's for winters. It puts the speedo off but big deal. Just do a bit of mental math to figure out how fast you're really going.
And some people have found that Tire Rack won't sell you a lower profile tire because the load rating drops to less than the factory rating. Just be smart about it and don't load the car up real heavy and take a cross country trip.
shojoe1997
new york
How did the 225/50 look on the car? Too small or not too much of a difference.
Ian Macoomb
It looked small. It didn't help that I used the MAD/*** springs (the highest load rating I believe). It made it look like an off-road SHO. I didn't care about the look. I was going for a shorter tire for the gearing effect.
shojoe1997
new york
Ok great thanks. Im probably going with a goodyear, they have alot of design on the tire so it kinda gives it the illusion of being smaller hahah. Thanks
