That plastic thing that holds the headlights..
apanthropy
My newly acquired 94 SHO was backed-into (before I got it), which destroyed the driver side turn signal housing and slightly bent the metal bits behind it, and really did a number on the black plastic thing that the headlights mount to.
I don't know what that part is called or where to get a new one... the two I found in junkyards were destroyed and it's quite brittle, so I suspect any original piece is equally wrecked.
I've used zip ties and good intentions to hold my headlights in place for now, and COULD fabricate something more substantial if necessary but want to fix it correctly - is that piece available? What's it called & where should I look? Searching rockauto led me to nothing :(
it is the same piece as a standard Sable of the same vintage. that helps when looking in the jy.
