I welded a metal box and slipped the ecu right in. Made it slightly bigger in order to put a Tweecer on it , plus I will try to foam pad it a little to help with the vibrations.
Its hard to see but its about a feet away from the muffler on the right.
Welcome to the parts. . . . Maurice
Phoenix - cool project. You got a progress thread for that beast?
Strap yourself , you will need more then 5 minutes.
http://www.shoforum.com/showthread.php?t=110952
http://www.shoforum.com/showthread.php?t=111032
http://www.shoforum.com/showthread.php?t=112784
http://www.shoforum.com/showthread.php?t=113289
http://www.shoforum.com/showthread.php?t=113516
http://www.shoforum.com/showthread.php?t=113660
http://www.shoforum.com/showthread.php?t=113707
http://www.shoforum.com/showthread.php?t=114521
http://www.shoforum.com/showthread.php?t=114910
http://www.shoforum.com/showthread.php?t=115164
http://www.shoforum.com/showthread.php?t=115282
http://www.shoforum.com/showthread.php?t=115443
http://www.shoforum.com/showthread.php?t=115919
http://www.shoforum.com/showthread.php?t=116034
http://www.shoforum.com/showthread.php?t=116301
http://www.shoforum.com/showthread.php?t=118354
http://www.shoforum.com/showthread.php?t=119169
http://www.shoforum.com/showthread.php?t=119826
http://www.shoforum.com/showthread.php?t=120255
http://www.shoforum.com/showthread.php?t=120423
http://www.shoforum.com/showthread.php?t=121827
http://www.shoforum.com/showthread.php?t=122758
That's almost as many threads as there are for the 914!![]()
OK, I heard that!![]()
If asking me. One ground is beside the computer. Other 2 hook to a #10 or #12 wire and run to ground bolt in body with battery ground on same bolt. . . . Maurice
