you've got to be kidding me
AeroSS_87
Lincoln, NE
So I go to the store and get my cam sensor. 31.99. awesome. double platinum plugs, 3.99 each.. great. standard oil, filters, pcv valve, etc.. done deal. Spark plug wires. $107 for borg-warner........... excuse me??? 151 for motorcraft.... holy crap!!! okay lets move on... valve cover gasket set. $85.... WHAT THE F*** DO YOU MEAN 85 DOLLARS?!?! daaaayyyyuuuumm. :bonk:
so... any suggestions on where to get these for a bit.. preferably a LOT cheape??? :oogle: :eek: :omg: :nut:
yamahaSHO
E85 whore
Arkansas
That is fairly standard for prices. You *may* be able to get them slightly cheaper from RCM Automotive.
AeroSS_87
Lincoln, NE
i just found some accel 8mm custom fit wires from summit for 70 flat. I figured what the ****... but man I need to do some looking for I spend 150 bones on some gaskets.
Jonny Cash
Good boy
Hollywood, FL
Your pockets will be hurting maintaining and modding your SHO, but you can get some Magnacores, or some Taylors for under 90 bucks.
haha..I said the same thing when I bought my first sets of gaskets..
SHOtimer
#2910
Santa Clarita, Ca
You got ripped if you bought a pcv valve for the SHO, as it does not have one.
Doug
PAracer
West Chester, PA
Accel wires are good for the SHO. Many aftermarket wire do not seal well on the valve covers. As far as spark plugs, Motorcraft, and I believe Autolite are the recomended brands. For some reason, the SHO is picky about spark.
You could get a full upper gasket set from RCM and be done with it. That will cover everything down to 3.0 head gaskets. 3.2 head gaskets cost more and are just receintly back in production.
Get a roll of vacuum line hose to replace the hoses that are most likely original and dried and cracking. Also, Permatex ultra-gray RTV works well and is sensor safe.
AeroSS_87
Lincoln, NE
wow thanks for the tips. I didn't know sho's were pcv-less. He probably looked it up for a standard 3.0 (vulcan? I think they call them) oh well. it's 1.50 and my g/f has a 92 probe 3.0 that could use it.. unless of course IT doesn't have one either. lol
:hpoop:
Off Road SHO
Moderator
kurtis adum said:
i would defintly go with the motorcraft or autolite plugs. whole dif car IMO
kurt
Agreed.
The Accel kit for the SHO is 5119K in black and is a perfect fit.
Tom
F-22 Raptor SHO
7015 feet above Sea Level
Ford Parts network guys. Shoforum sponsor and supplier of stock OEM motorcraft plug wires for 99 bucks. Thats cheap considering you replace them every 60k.
gaskets: ebay
stick
SHO Addict
in a distracted state
:hpoop:
If he did your other stuff wont fit either.... Advance Auto has the Valve covers for $71
morpho18
Des Moines, Iowa
i picked up the felpro valve cover gasket set for about 80 bucks from O'Reilleys when I did mine last year. about 120 bucks total for plugs, wires, and gasket set.
Devin
3.Slow
Pacific Northwest
Don't talk to me about gaskets. I've purchased about $150-$200 in gaskets by this point.
Wires are simple by comparison!
