WTF!! These cpu's suck a$$!
cRaZySHO.
norwalk, ct usa
I fixed my throttle position sensor code, and my ACT sensor code. And now my check engine light comes on. I get home, I checked it, and no codes came up. I noticed my does a weird slipping/bucking thing now. On a constant throttle hold, the engine feels like the clutch is pushed in and then released really quick. Which gives me a quick hesitation. It only does it some times. And I thought it sounded like an ignition problem. So I checked my wires and plugs. All connections were tight, but I had oil in plug wells #2 and #5. Could this be causing the bucking? This is sad, I sell car parts for a living. Thanx guys. :confused:
Diameg
Ontario, Canada
Hmm...sounds odd that the CE light comes on but throws no codes.
On the issue of the bucking and hesitation, I have had that twice.
The first time, it was very noticable and I described it the same as you have. It feels like the clutch slipping, especially at anything over 1/2 throttle. Really felt like clutch or tranny problems.
I had oil in the #2 plug well. Replaced the wires and plugs (as well as plug well seals), and it was as good as new.
Recently, I had what felt like a more minor hesitation at around 3000 rpms only at WOT. On a suggestion from someone else, I replaced my fuel filter and the hesitation is gone.
Looks like you gotta open it up and replace the seals along with plugs and wires. Should smooth everything out.
cRaZySHO.
norwalk, ct usa
I have a list of parts for next weekend that I might install- considering my current legal sitch. How do these sound- shims and shim tool, valve cover gasket w/plug well seals, intake gasket set, Motorcraft plugs, IPT wires, 12 cans of carb cleaner, 2 cans of black, primer, and clear coat engine enamel for the manifold, Motorcraft FG800A fuel filter, Holley 155 lph fuel pump, Ford Motorsport 24lb per hour injectors, modified fuel rails, 6 qts of Mobil 1 synthetic and one Motorcraft FL400S oil filter. I have all these parts brand new in my garage, I think this will cover everything for a nice "little" tune up. Car should run good after that, if I decide to do it. I figure this will be an all Friday night through Sunday night job. I will be doing this by myself.
Are you going to keep this for later? Sounds like alot of work. I thought you were going to sell everything.
cRaZySHO.
norwalk, ct usa
My mind has been going in a million directions lately. First I tell myself to do it just get it over with, then I'll say that f**k it, I won't do it. I will most likely do the gaskets and the shims, seeing that those are just maintenance items. The upgraded fuel system parts will most likely be sold to you guys.
sho_dwn
Rolla, MO
Just a thought-I just fixed my car and it had the same problem yours sounds to have. It was the computer. I switched it out with the one in my Plus and it runs like a champ now. I couldn't even scan my codes because it wouldn't flash anything. Turns out the computer I pulled out was a reman. so someone had problems before. Just my 2 cents.
