Marccus
What wrench sizes / sockets above 19 mm are required to work on the '89 SHO?
I've pretty much worked on the engine and other areas where the largest size that was needed was 19mm,. Suspension bolts are much larger. From what I've read in the standards (American, British and DIN), there aren't any standard bolts listed for use with 20, 23, 25mm spanner sizes. So I'm thinking that you only need 21, 22, 24, 27mm above the 19mm size.
Low on funds, so I need to buy only what is essential.
