Will 17" wheels fit on 2011-2012 SHO's?
MNRubyRed2013
Minnesota
Does anyone know if 17" wheels will fit on the front of a 2011 or 2012 SHO?
I have a set of Blizzaks/wheels/TMPS I need to sell, since I traded my 2010 for a 2013 and they do not fit on the front.
I never put them on my 2010, but the previous owner of them had them on a 10 for 2 winters.
MNRubyRed2013
Minnesota
If you have a 2013 with PP and the larger Caliper & brakes then it will probably not fit.
My 2013 does not have the PP and they still do not fit. Just trying to see if they will fit a 2011 or 2012. I want to be sure before I list them for sale.
SHO U UP
SHO Guru
Virginia Beach, VA
IIRC, the spare tire and wheel are 17" so they should fit the 2010-2012 without an issue. The brakes were increased in size on the 2013 models so the smallest rim/tire combo should be an 18" for those.
EcoBrick Bob
Clear Lake, IA Naples, Fl
They also will fit 2009-2012 Flex and many other Ford vehicles with the 114.3mm bolt pattern. They may need hub rings to become hub-centric, but if you are careful and tighten slowly, Lug-centric will still give you a "balanced" ride.
TuxBlack
Montana
I have a set of 17" rims and snow tires for my 2010 without PP. I got them from Tire Rack, and they recommended the 17" size wheels. They fit just fine, no problems.
MNRubyRed2013
Minnesota
Thanks for the info ****/Bob. That hopefully should make it a bit easier to sell the wheels and snow tires.
