where's the best place for sway bar bushings
Mike Stitzer
PA
I have a 26mm rear sway bar that I will be installing on my 95 SHO MTX. Where can I get the poly bushings for the best prices. Also, do I need to get the strut rod bushings as well. And do I need to get a stiffer endlink or will the stock ones hold up to the stiffer 26mm sway bar? Does anyone sell endlinks only?
Mike
marlonius
Holden, MA
Definitely replace your endlinks with heavy duty ones. I got endlinks and bushings for my 26mm bar at CincySHO. I know there are other places you can get this stuff, too. I haven't gotten around to the strut rod bushings myself, but it is definitely on my list of things to do.
LaTechSHO
Louisiana
if you want poly bushings...
rear strut rod bushing set = 47120G
rear end link (just 8 bushings not rod) = 98105
rear sway bar bushing = 95161G
those are energy suspension bushing numbers
for the sway bar bushings...you'll have to drill & tap 1 hole per side since the factory bushings have only one bolt hole and a tab that goes into the subframe for the holder braket..... energy sus. bushing braket has two bolt holes
Louis
LaTechSHO
Louisiana
sorry..i apparently can't spell bracket.... but i also meant to post
i paid $18 for the strut rod set
$14 for the sway bar bushings
and $7 for the end link bushings
so it isn't expensive
Louis
Brad kirk
