VA. Beach SHO
Yep. Green '93. There are a few SHO's around but not as much as there used to be-- unless you count the new eco boost cars
Rodney Wilson
Who does the work on your SHO? Any good local SHO mechanic's you can recommend
Not really. What kind of work do you need?
For big stuff I consider taking it out of town if it's drive-able. I used to do my own work but I don't have time to do much more than brakes or plugs and wires and easy stuff. There are some guys around Richmond that may or may not still do work. After that I would take it to PA if it needed a big job done. If it's not deep motor work a good mechanic can replace a clutch or install brakes.
If you are young and budget concious this car will make you learn alot about fixing cars from having to do it yourself
Rodney Wilson
It is very much driveable. I need the lower timing cover replaced. This is pretty much a daily driver. I got it because the price was right. And no I'm not young. lol. Well I'm 39. so in my eyes I'm still young. Lol
SV&HOdan
Pittsburgh PA USA
Welcome to the wonderful world of sho ownership. If you end up needing that lower timing cover, I should have one in my stock of parts.
I've dismantled more that 20 shos and have a lot of parts around. Auto or 5-speed? Good luck finding a decent mechanic!
dan
[email protected]
412 539 6294
Rodney Wilson
I have a auto. 3.2 if that matters. I'm a definitely need it if you have it. And yeah I'll need all the luck I can get. lol.
If it's your daily driver then.. yes you will. Dan has great prices. Save his contact info for future parts you may need. The timing covers come off in a specific order which is why some of them are usually broken. Take them off out of order and stark yanking on them and it's not hard to break them.
Kevin is Richmond area. I haven't seen **** on here in a good while. I saw him working a few times last summer. Maybe he's on the facebook group.
kevinspann
Don't take my advice.
Richmond VA
**** is around. Not sure if he has the time, but he does have a lift. But yes, I'm in Richmond. The hardest part of the job should be tightening the crank pulley. My labor is cheap :)
Rodney Wilson
My brother lives in Richmond. if you have time. Give me a call. Whenever you are free. I don't mind the drive if I can get things done correctly. 757 349 4760
Rodney Wilson
My brother lives in Richmond. if you have time. Give me a call. Whenever you are free. I don't mind the drive if I can get things done correctly. 757 349 4760[/QUO
I forgot to mention, I don't need the lower timing cover replaced. I think I need the camseals replaced. Can you install the gaskets.
acid20016
Having trouble with lines uder throttle body on left and rite whete do yhey go on a 92 2nd gen sho
Sent from my SM-G930P using Tapatalk
acid20016
Can you help 92 sho 3.0 need help with the lines that r under th throttlebody on the left and rite where do they go
poffffd
