The cars running roughly and sometimes sounds as if it will die but doesn't. We ran KOEO and KOER testing process and got the following codes:
111 - System checks OK
116 - (O,R) Engine Coolant (ECT) sensor out of range - ECT
136 - (R) Oxygen sensor not switching/system lean Left or Front HO2S - Fuel control
167 - (R) No Throttle Position sensor change in "goose" test (must get at least 25% rotation) - TPS
172 - (R,M) Oxygen sensor not switching - system is or was lean - Single, Right orr Rear HO2S - Fuel control
214 - (M) Error in Cylinder ID (CID) circuit or signal - Ignition Systems
225 - (R) Knock sensor not tested (ignore if not pinging) - KS
332 - (R,M) EGR did not open/respond during test or if memory code, did not open intermittantly - EVR or PFE
I got these definitions from this link http://www.shophoenixproject.com/eec/code3.htm
Any suggestions on where the **** to start would be greatly appreciated.....
Thanks in advance.
Thanks in advance.
