Tires sizes
Shokev
Philadephia
Hey need some suggestions i want to get wider tires for more grip i have 255 45 19 on my sho now. What do you think is a good size to go up to?
275's. However explain the grip you are looking for?
Straight line grip? Cornering grip?
If you go wider, you will need new rims. If you are looking for a good all around tire....I run the Continental Extreme Contact DWS06. They are awesome.
Shokev
Philadephia
I plan to get a different set of rims anyway so that coo. I plan to put h&r springs on too do you think there will be clearance issues ?
Look into the Sho me your rims thread. There is some good info there.
xFallenxCripplex
Have you recorded your g's I get 1.02 with the stock pp tires
Where I get only .80 with winter tires
Got a set of Michelin PILOT SPORT A/S 3+ on the way going to try mainly just wanted a tire that did pretty well in a straight line and was all season low on noise and hoping for at least 5 years before I need a new set
https://www.google.com/amp/s/www.mo...motor-trends-top-figure8-performers-3095/amp/
Sent from my Pixel 2 XL using Tapatalk
Lostneye
NY
I'm running those Contis, great all around tire.
275-40s on 20x9.5 et35 with H&Rs. Slight rub in the rear occasionally with big dips in the road potholes and speed bumps don't seem to be an issue. I haven't got round to look where but from other threads I think it's an easy fix.
That is all the info you need right there to run 275's on all corners....thank you sir.
