sway bar GENI/II matching GENIII???????
gen3performance
south central P.A.
i think i read this right but i want to make sure . ok does the later model shos (v6) sway bar bolt right up with the genIII . is the sway bar on the later model bigger then the genIII .is this the front and the back sway bars or just the back .what year genI-genII is the match.If so i will be heading to the junk yard on Monday.thanks guys
gen3performance
south central P.A.
what year is that and did it make a difference .did you get yours outa the junk yard ??? if so what did it run you??is that just the back or front to ????
LOUDSHO92
Sponsoring Vendor
Rancho Cucamonga, CA
89-90 ran 24/26 for sure. I know the 92 ran 24/23 but the 91 I am not sure I have read (SHOShop) that the 91 ran 24/23 but I have heard of it running the 24/26. For 93+ they ran 19/22 (front or rear) and they were never consistant.
So stick to the Gen1's for sway bars.
If you use a GEN 1-2 front sway bar be sure to add some split collars to it on either the inside or outside of the bushings. Otherwise it will slide back and forth about 2-3 inches.
dan.delargy
