Sunroof drains clogged??
Matthardin86
Winder Georgia
I have water on the floorboard on passenger side, also get water in the trunk too. I’m guessing it’s from the sunroof drains being clogged. Any help on easiest way to clean them, where they’re located?
15fosho
lexington sc
Can't answer 100% on the trunk but after a monsoon of rain came through sunday my entire headliner was soaked and cupholder full of water. I opened the sunroof and in the front 2 corners will be small black holes where the water drains. I put water in the tray and had no water draining out of left side and minimal draining out of right side. cleared blockage with air gun and all is well and draining properly. if you use air gun to clear block be careful not use to much pressure or can have hose pop off behind pillar etc.
mission bc canada
i ran into this problem ( again) last week - i ran a little plastic tube( left over boost gauge clear tubing) down the opening - twisting it as it went down - then used my air gun on the end- couple bursts - cleared out right away -
