Sumitomos anyone?
pbshow
Lake Elsinore, CA USA
I was wondering if anyone has now or have had Sumitomos on their SHO. The tires that I am looking at are the 225/45-16 HR-Z. Also, how much am I going to give up in ride to switch from a 55 series tire to a 45 series tire? Any help will be appreciated.
Paul
They will leave the rims more susceptible to impact damage, provide a more impact sensitive ride and create an 8.35% speedometer error (indicated 65.0 mph at an actual 60.0 mph). They will also make your fender gap look very large. Much like you put too small of a tire on the car. Hey, it IS too small a tire.
Scott
1991, 252K miles, glass hood, police grill, SVO shifter, Catz fogs,
Eibach/Tokico/polyurethane, SHO Shop front & rear strut braces,
Class II hitch, Silver award at the SHOklahoma Car Show
smokesho
Ont,Canada
yeah, a 45 series is a bit too small. and you WILL notice a ride difference, every bump and train track !!!
white 92 MTX,
turbo mufflers w/ 21/2 inch tips
est 15.1
pirelli p4000 50 series
more to come....i hope
coming soon....jbl 10'
performance y-pipe
rlw001
Reading, PA, USA
I run Bridgestone RE040s 225/45/17 as my summer tires, they handle great but have alot of "road feel". I just put my slicers 55 series tires back on, just about perfect ride but all-season tires are not the hot setup. I would not go smaller than 55 unless you want huge wheelwells.
Bob W
94' ATX, SHOshop Y-Pipe, SHO Shop UDPs, 70mm FPS MAF, SuperChip,
K&N Panel, Coneless, 96' Brake Upgrade, Colgan Bra, PIAA 1552 Driving Lights, Eibachs/Tokicos, 24mmFSB, 26mmRSB, Subframe Connectors, 17x8 TSW Hock Rs, 225/45/17 Bridgestone RE040s, 255lph Walbro Fuel Pump.
FAST4DR
Paul
I have the Summitomo HTRZ II tires in 235/45-17 . I love them. They are the extremely quiet and extremely sticky. They are one of the least expensive and best performance tires I have owned. They are also excellent in the rain. With the 45 series tires you will definately feel more bumps and firmness but it is not that bad. What you will notice is that the car has a sharper turn in because the tires are not squirming as much side to side. The only negatives I can think of is that they are so sticky they pick up little gravel like crazy. I only have 10,000 miles on them and mine are worn out. I drive very aggresively pushing and sliding through about every turn so I think if you drive normal you should be able to get 20-25,000 miles out of them.
William
www.wclewis.com *** YAMAHA - SUPER HIGH OUTPUT BADGES ***
95 Red/Tan MTX -- Torque Limiters -- K & N panel -- PIAA Driving Lights -- PIAA platinum super white's --
F&R Strut Tower Braces -- Subframe Connectors -- 96 Brake upgrade
17x8 Fittipaldi Tubolares w/235/45-17 --24 & 26mm F&R Sway bar w/poly
Sachs Clutch -- 255lph Walbro Fuel Pump -- MTX Drain
Stereo - Clarion AutoPC Navigation system
Avital 6500 - Auto Start & Security
Installing Soon --- Shoshop Y-pipe -- 13" baer brakes
[This message has been edited by FAST4DR (edited 11-20-2001).]
