Strut mount part numbers?
SHO EET 1
Chicago
I'm confused on what strut mounts and front strut bearings to buy for my 94 ATX. I see SHONUT lists several part numbers but I just want to make sure I receive the correct ones. I will be purchasing the Tokico/Eibach combo.
shoinoff95
Wichita, KS
Read this on choosing strut mounts and bearings directly from SHO NUT's site written by Josh!!
For replacement parts, Ford has two dimensionally different front upper strut mounts and two dimensionally different front bearings, which they specify in three different combinations. Each of the front strut mounts come in standard rubber (black) and HD (painted blue). For 89-90 (as replacement parts – who knows what came from the factory), the SHO gets the HD blue piece, as do the Police. The SLO, of course, gets the standard rubber. For 11/90-95 the part changed dimensionally, and the SHO is specified to get the SLO piece, with only the Police getting the HD blue part. Since the blue (Police) and black (SLO/SHO) parts in a given year are dimensionally the same, they are interchangeable. The bearings also changed dimensionally.
The parts are:
(won't bother listing the early SLO piece)
89-90 SHO/Police Front Upper Strut Mount AD-923-A/E7DZ-18183-AA (obsolete)
11/90-95 SHO/SLO Front Upper Strut Mount AD-930-A/F1DZ-18183-AA
11/90-95 Police Front Upper Strut Mount AD-931-A/F1DZ-18183-BA
89-11/90 and 94-95 Front Strut Bearing F4DZ-3B455-A
11/90-93 Front Strut Bearing F1DZ-3B455-A
As you can see, the first bearing is used with the two front mounts. More on that below
Here are the dimensions of the mounts for top of mount (i.e. underside of strut tower) to bearing mounting surface:
89-90 mount 0.49"
11/90-95 mount 0.88"
As we can see, the newer mount places the bearing mounting surface further down WRT to the top of the strut tower. The height of the centre portion that mounts the strut shaft does not change between the two, however ...
For the bearings, it's difficult to measure the bearing surface to spring mounting surface, but the F4DZ part has the spring mounting surface 0.15" below the bearing mounting surface in the mount, while the F1DZ part has the spring mounting surface 0.18" ABOVE the bearing mounting surface, i.e. the F1DZ bearing has a very deep cup.
When you put these together for the different years as specified, you get the following top-of-mount (i.e. bottom of strut tower) to top of spring distances: (remember that in all cases, the strut shaft mounting hole vertical placement remains the same in either mount...)
89-90 Front Upper Strut Mount
0.64" top of mount to top of spring
11/90-95 Police or SHO/SLO Front Upper Strut Mount
0.70" top of mount to top of spring
1.03" top of mount to top of spring
There are at least three points to gather from this info:
1. The rubber ring on the outside of the bearing part that sometimes makes contact with the strut tower, and thus noises (for which the spacer recall is to correct) is quite a bit higher in the first two examples, whereas in the 3rd, it is quite far down. Thus the last combination should never need the spacers to correct noise.
2. The latter combo raises the front of the car by about 0.35" compared to the first two.
3. The latter combo, by maintaining the same strut shaft mounting height, while having the top of the spring down further, actually increases available strut compression travel by the same 0.35" (with a corresponding decrease in extension). Note that while a spacer (which mounts on TOP of the strut mount) raises the car by about 0.25" and moves the top of the bearing 0.25" away from the strut tower, it does NOT increase available compression travel, since the strut shaft mounting location in the mount is also lowered. Note that 'lowered' and 'raised' all depend on your point of reference ... :)
Based on the above, I would always recommend the 11/90-95 Police Front Upper Strut Mount for all cars for 2 reasons:
1. It has harder rubber than the dimensionally equivalent SHO/SLO piece, so thus should provide more control of the strut's movement, increasing its effect.
2. The equivalent Police 89-90 piece is obsolete.
If available strut compression travel (i.e. resistance to bottoming out) and lack of rubbing noise is more important than lowering the front of car by a paltry 0.35”, then I recommend the 89-11/90 and 94-95 Front Strut Bearing for all cars. Since this would be the most important to me, I would recommend the 89-11/90 and 94-95 Front Strut Bearing for all cars, period.
If lowering the front of the car is more important than eliminating the strut noise and increasing available strut compression travel, then I recommend the 11/90-93 Front Strut Bearing for all cars, but bear in mind that you may have to add spacers to eliminate rubbing noises, and then you increase the ride height without any corresponding increase in compression travel.
If absolute lowest cost on Ford parts is the main concern, then the lowest price combo is the 11/90-95 SLO (and specified by Ford for the SHO) Front Upper Strut Mount and the 89-11/90 and 94-95 Front Strut Bearing.
Joshua Teixeira
SHO EET 1
Chicago
So, the best set up should be the:
shoinoff95
Wichita, KS
I would say that it is; it is probably what I am going to go with when I buy my mounts and bearings to finish up my lowering project! Plus Josh at ShoNut recommends it, it ought to be the best combo; he really knows his stuff! thumb
shojuan
sunny San Juan Bautista,
SHO EET 1:
That's the combo I got. If you want to lower your SHO the maximum possible with the springs you got then go with the other bearing. This combo has no risk of rubbing noises though. But lot's of people have used the other bearing without encountering rubbing noises. It's your call.
