Izzmo
SHO Enthusiast
I might be in the market for new struts and/or springs.. but first I need to know if they are even bad.
I went to Ford and had them do that 120.. or 200 or whatever the **** multi-point check bullcrap ( I doubt they check your whole car.. I swear it). They said my struts and springs looked good, but I'm doubting their expertise.
1) How do you know if a strut is bad? I looked on the net and to answer some questions that you guys may ask:
- No, my car does not bounce a lot after going over a bump
- No, my car does not sway (I have upgrade sway bars.. so this may be why my car down not bump or sway)
2) Should springs last the life of the car? I saw this on a couple other forum topics but was not sure if this statement was true or not.
3) If my struts are bad, what kind of struts should I get? It seems as if it will be between KYB or Monroe as I can't find Koni's anywhere.
4) Should I get just the strut or should I get the whole assembly (strut and spring)
5) If I'm going to replace the strut, do I need a new strut mount assembly, or can I use the one already on the car?
Thanks for any and all help.
