Secondaries Stuck Open..
Kens1992mtxSHO
The Commonwealth
...for about 500 miles of driving. I've fixed it already but can this do any damage? I've looked on the forum and didn't see anything to definitely answer this question.
Thanks
Kens1992mtxSHO
The Commonwealth
Thanks,
I didn't think any damage would be done but I also wasn't sure of anything else I needed to do besides making sure my secondaries opened and closed properly.
I appreciate it!
True, there was no damage, but you will never get back those lb-ft of torque that were lost below 4000 rpm when they were stuck open. ;) It's good that you made it right.
MIsho91
Saint Joseph MI
******* question i know, but ive spent close to a half hour on google trying to figure this out and id love a definate answer. the "secondaries" are ...secondary intake WHAT? im used to diesel so its all new to me with the sho. although i can say that the intake isnt as complicated as many see it, its 3 pieces in actuality...nother question, car is running ****** and im leaking fluid, almost positive its the water pump. im gonna replace it, what is needed to reach it? can i do it as it sits?
sho'd
Git R' Done
ontario,canada
when i bought my car i had the same problem, it ended up being the solinoid runner control, the little solinoid at the back of the intake attached a little black vacume canister, you can test it with a DVM for continuity, i have a few laying around, if you need one, pm me. good luck. Mike.
hawkeye18
Sorta cares
Norfolk, VA
what are you talking about, not complicated? I've got a brand new intake all layed out ready to go on my wife's car, and I can count over 14 individual chunks of metal.
Lesson time! Ok, I'm sure you're familiar with intake pulsing - air bouncing off the intake valves that suddenly are closed and pulsing back up the intake, bouncing back off the intake and going back towards the valve. You want those pulses of air hitting the valve at the same time it opens for maximum effeciency.
Thus, the long set of runners, for use below 4k rpm. The long tubes provide enough length for the air to bounce back at the lower, slower RPMS.
Once the rpms get up there, though, those tubes are just too narrow and too long for the air to efficiently move at the higher speeds and faster valve action of the higher RPMS. that's why the butterflies open up, to divert air to the wide, short runners that deliver a must faster pulse length. Basically, it gives you two different torque curves, both optimized to the RPM band that you're in.
Most intakes use a medium width, medium length runner as sort of a compromise between the two situations, but it's not optimal. This intake does not compromise, and that's why you feel that huge kick in the pants when you hit 4k RPM... if those butterflies are working! It's like VTEC, but a lot better.
